Aluminum flatback for unstyled A
GA Puller
04-20-2006 18:32:42
Has anyone bought an aluminum pto flatback for an unstyled A from K&K antiques??? I bought one to lighten the load. I was told by K&K that I would need to drill the holes. No problem, drilled the holes yesterday, lines right up. However, as I'm drilling the holes, I notice there is very little clearance around holes to edge of aluminum. Matter of fact, had three to just barely break thru, no big deal. Today, I realize, even though all holes line up, the bull gears are hitting this thing in several places,, not enough clearance!!! This aluminum was sand casted, have I gotten a defected piece, last of the mold, or am I suppose to get crazy with a grinding wheel?? I don't believe this will solve the problem though, since there is roughly 1/4" gap all way around. The casting isn't but 5/16 thick. Will this be enough?? I just wanted to see if this is normal. Thanks in advance.
