JD 60 with powerblock
Kevin
04-20-2006 11:25:53
Just wondering what the bore and stroke dimensions should be on a jd 60 with a power block? Also does 75 hp sound about right or do we got something wrong?
R W Wisehart
04-20-2006 18:30:27
 Re: JD 60 with powerblock in reply to Kevin, 04-20-2006 11:25:53
John Deere A with power block is more like 47 on dyno. I know because I had one last year and ran it on my dyno a couple of times.
loveable
04-20-2006 14:06:40
If a power block is all that has been done to your tractor, then you have a 6.75" stroke and I believe (but may be wrong) that the bore on a 60 Power block was 6.125". 75 horsepower is definitely high if ALL that's been done to the tractor is have a power block put in. 55 hp is probably more likely.
Mike Aylward
04-20-2006 17:47:05
 Re: JD 60 with powerblock in reply to loveable, 04-20-2006 14:06:40
The Power Blocks for A's and 60's originally had a 6 inch bore. The stroke mentioned is correct. Around 55 h.p. is about right at rated speed if the tractor is otherwise stock. Hope this helps. Mike
JD hauler
04-20-2006 19:28:37
 Re: JD 60 with powerblock in reply to Mike Aylward, 04-20-2006 17:47:05
your A has 6 3/4" stroke and a 6" bore, its now a 382 cid engine, 55 hp is a stretch without alot of intensive head work and camshaft work , you at best pick up 10 hp on this combo. put a 9 1/4" crank behind that powerblock and it will run really well for you, and will live a long time, would be around 545 cid.
Mike Aylward
04-21-2006 06:06:55
 Re: JD 60 with powerblock in reply to JD hauler, 04-20-2006 19:28:37
Fifty five h.p. is very doable. My 60 has a similar setup in it and it runs more than this at rated speed, tested on my own dyno. Higher numbers can be had but not at rated speed. Mike
Fox Trot
04-21-2006 11:59:11
 Re: JD 60 with powerblock in reply to Mike Aylward, 04-21-2006 06:06:55
a
A
I have a 1950 A with a Heisler Head, Bored 0.125 over, stock stroke. Tractor pulls 5700 lbs, 6200 lbs, 6700lbs, and on a good day with out a good bitting track can pull 7200 lbs. This is with 16.9 38 tires. This tractor has creeper gear but we pull in 2nd gear in all these classes most of the time. Was just wondering if anyone would make a guess as to how much HP this tractor would be making? Thanks for any input. Oh yes this tractor has stock cam.
