JB B too fast in First
oak
04-17-2006 06:49:55
Any one know how to slow down first Gear in 43B 1st gear is to fast for power output? Plus the horn will blow and I have to throttle back? Your Help would be apreciated.
jd b puller
04-18-2006 09:12:00
 Re: JB B too fast in First in reply to oak, 04-17-2006 06:49:55
Oak, what rules will allow you to blow the horn in 1st gear on a B???
Oak
04-23-2006 16:20:49
 Re: JB B too fast in First in reply to jd b puller, 04-18-2006 09:12:00
Maumee Valley Pullers Pull- Div 2 Tractor May Be Overreved but. Not Competitive. Need to slow it Down to use What Power it Has . After Reading all the listings I think it would be best and Easy to go to Smaller Dia Tires . Tractor May not look the way I would Like but Should Help. Or go down to Div 1 Stock Pulls only
Rekabnivek
04-18-2006 19:35:52
We have a '39 B, here in Southern VA, that will " blow the horn" in 1st gear in the 3MPH class!! The sled has a manual overide that may be used when we pull. There are some clicks here and we are not in one!!!
jd b puller
04-19-2006 10:13:11
 Re: JB B too fast in First in reply to Rekabnivek, 04-18-2006 19:35:52
I was thinking that 1st gear was about 2.5MPH, must be running over RPM's.
Jak
04-17-2006 10:20:52
On an A you can change the reduction gear on the side as well as the gear on the pulley and sloe it .5 mph.A B should be the same.Find a junked out late model B with a six speed and change them out.
WTW
04-18-2006 09:10:08
 Re: JB B too fast in First in reply to Jak, 04-17-2006 10:20:52
Jak, Not so easy on a B because diameter of clutch pulley hub where clutch gear is pressed on is larger on the later models and the first reduction gear and shaft are also larger. It could be done by swapping spider / centers of first reduction gears that have removable spiders and some machine work to make spacer on pulley gear. Never did this on a B but did consider it years ago, just decide to put the effort toward a little more power and shift it up a gear instead! DW
Jak
04-18-2006 14:37:59
 Re: JB B too fast in First in reply to WTW, 04-18-2006 09:10:08
Thanks Dave,I wasn't sure but figured a B was about like an A in that area but a tad smaller.Jack
