running high compression with a mag
slowsmoke
04-15-2006 06:55:08
Is there a compression ratio "limit" that a distributer will work better than a mag? can't get timeing right, wondering if a dist. with the mech. advance would be better. Comp. ratio is around 10/1. Thanks
MMark
04-15-2006 15:35:11
 Re: running high compression with a mag in reply to slowsmoke, 04-15-2006 06:55:08
You may get different opinions, However, It should not make any difference. We have run mags on V8"s for a long time with no advance at up to 14 to 1. With a low speed engine an advancing distributor should be at an advantage if your rpm"s change through out the pull.
MMark
Family Tradition Pulling
04-17-2006 20:12:17
 Re: running high compression with a mag in reply to MMark, 04-15-2006 15:35:11
Ran a mag at 10:1 ratio last year. It would run fine, but starting the tractor... no way. I recently sold the tractor, with my MSD 6 Box that I had plans to put on this year.
