SAT II 23 Degree Firestone Tires - Come get 'em.
Lamont
04-12-2006 20:27:01
third party image
Several of you guys were interested in these tires and I've been trying to get these for some time now. I finally was able to order 10 sets of them. They are 15.5 x 38 Firestone Super All Traction 23 Degree 8 ply rating BLEMS. $685.00 PER PAIR. See photo ads #132965 or #132966. Won't last long. I normally don't post ads on this page but several people have been interested in these. Thanks.
Turtle Gears
04-13-2006 18:30:00
 Re: SAT II 23 Degree Firestone Tires - Come get 'e in reply to Lamont, 04-12-2006 20:27:01
Lamont- them look like some good tires,I may need to get a set off of you for the TURTLE!!! T.G.
Lamont
04-13-2006 18:38:11
 Re: SAT II 23 Degree Firestone Tires - Come get 'e in reply to Turtle Gears, 04-13-2006 18:30:00
They'd make some good Turtle shoes. Might be a little too big though.
Pete1468
04-13-2006 15:11:23
I just bought a set of sat's 8 ply 15.5's that aren't blems for $600 from the firestone dealer.
Lamont
04-14-2006 21:18:01
 Maybe the difference. in reply to Pete1468, 04-13-2006 15:11:23
There is a little difference between the SAT and the newer SAT II. Maybe that's the price difference also.
Lamont
04-13-2006 16:02:22
 Re: SAT II 23 Degree Firestone Tires - Come get 'e in reply to Pete1468, 04-13-2006 15:11:23
Most places around here are charging over $450 a piece. Sounds like you've got a heck of a good deal. Maybe I need to re-negotiate my cost with my guy. Thanks.
Lettering
04-13-2006 08:34:54
Looks like the lettering is ground off the side, what is the deal with that?
Lamont
04-13-2006 09:23:14
 Re: SAT II 23 Degree Firestone Tires - Come get 'e in reply to Lettering, 04-13-2006 08:34:54
The word FIRESTONE is ground off at the factory. This is because these are BLEMS.
Black Widow Puller
04-13-2006 07:35:37
I would be interested in a set they do look like they have a taller sidewall from the picture is my assumption right.
Lamont
04-13-2006 09:23:54
 Re: SAT II 23 Degree Firestone Tires - Come get 'e in reply to Black Widow Puller, 04-13-2006 07:35:37
Yeah. I've been working on this for about 6 months hoping to get them in a large quantity. It looks like 10 sets at a time is going to be about the limit. I guess Firestone just don't have that many blems. To answer your question, it is about an inch taller. According to the chart, it's only about 0.6 inch taller. However, it is 0.2 inch wider and has a circumference 1 inch greater. All this adds up to a flat plate of 200 sq. inches which is the SAME AS THE 14.9 X 38 FIELD & ROAD!!!!! Compare the old 15.5 X 38 Field & Road with a flat plate of 189 sq. in. Multiply that difference of 11 sq. in. per tire by 2 and you get 22 sq. in. more in contact with the ground. To give you an idea of how they compare to a RADIAL 23 degree, the Radial flat plate is only 10 sq. in. larger. Most clubs don't allow the radial. This is as close to a radial as you can get. In my opinion this tire has got to be the tire of the future for the lower weight classes with size limits. Oh yeah, let me give you the other good news. A SET of these tires are 14 lbs. lighter than 6 ply 14.9 x 38 F&Rs, 32 lbs. lighter than 8 ply 15.5 x 38 F&Rs, and a whopping 222 lbs. lighter than 15.5 x 38 23 degree radials!!!!! Everyone used to want the 14.9s. NOT ANYMORE!!!!! As you can tell I've spent a lot of time on this but I thought it was important since most clubs have adopted the 15.5 x 38 tire limit in the lighter Farmstock classes. You know what I'm gonna be running. How many you want?
ChadS
04-13-2006 06:10:57
I did not know they made those in 15.5's! Good looking tire! We cant get em anywhere around here, I got a set of them in 18.4X34 new, (2 years old). How tall are the new 15.5's? They look like they have a taller side wall,,, Chad
Lamont
04-13-2006 09:21:03
 Re: SAT II 23 Degree Firestone Tires - Come get 'e in reply to ChadS, 04-13-2006 06:10:57
champspa
04-13-2006 14:45:29
 Re: SAT II 23 Degree Firestone Tires - Come get 'e in reply to Lamont, 04-13-2006 09:21:03
tiretown sells blems look at their site for pricing, www.tiretown.com
Lamont
04-13-2006 16:13:41
 Re: SAT II 23 Degree Firestone Tires - Come get 'e in reply to champspa, 04-13-2006 14:45:29
Yeah. The way it was explained to me was the price listed on their site was the "low end" for that size. They go up form there. The Firestones were nearly $400 each.
TIREDEALER
04-13-2006 16:31:56
 Re: SAT II 23 Degree Firestone Tires - Come get 'e in reply to Lamont, 04-13-2006 16:13:41
ITS DOES SAY 225 FOR THE 15-38 WHAT//////A DEAL.
Lamont
04-13-2006 16:37:09
 Re: SAT II 23 Degree Firestone Tires - Come get 'e in reply to TIREDEALER, 04-13-2006 16:31:56
There are a lot of 15.5 x 38 tires you can buy for even less than $225 each. Go ahead and get the price for the Firestone SAT II 23 Degree and see what the price is.
