Intake Manifold and Carb for 88 Oliver
Jerry
03-26-2002 10:20:41
I'd like to put a higher performing (flowing) intake and carb on an 88 Oliver head. What is an interchangeable combo that would work---like a 1650 manifold/carb setup etc... that would be less restrictive than the stock 88. Or what other ideas have you done to your intakes/carbs, using the stock 88 head. Thanks for your help and replies.
Pete1468
03-26-2002 15:44:35
 Re: Intake Manifold and Carb for 88 Oliver in reply to Jerry, 03-26-2002 10:20:41
I have a carb off of a JD combine that I would get rid of if you would need it. That's what I put on my puller and it made a difference. I beleive the throat size is 1 7/8.
88 Puller
03-27-2002 10:14:00
 Re: Re: Intake Manifold and Carb for 88 Oliver in reply to Pete1468, 03-26-2002 15:44:35
Pete--
I'm interested in your combine carb. What's the throat diameter and will it bolt up to an 88 or 1650 manifold? What's the price?
Pete1468
03-27-2002 15:09:21
 Re: Re: Re: Intake Manifold and Carb for 88 Oliver in reply to 88 Puller, 03-27-2002 10:14:00
I'll try to measure the carb tonight, my e-mail is [email protected] e-mail me and we can talk about it.
Brian
03-26-2002 13:13:40
There is a carb off of a JD combine (someone can help with the model) that has a bigger throat and works well. Not sure about the manifolds.
