Timing
hahter
04-11-2006 19:27:17
At what rpms do I set the timing on a JD G with distributor with electronic ignition. Also do I set it mark to mark on flywheel and cover, or do I run it advanced or retarded to those marks.
Thanks in advance.
the preacher
04-11-2006 19:49:40
 Re: Timing in reply to hahter, 04-11-2006 19:27:17
Just my two cents, but I set my timing on a dyno under full load. Granted, I have a MH 44 with a 4-cyl., but I think the principal would be the same. I figured that since the tractor would mostly see a load while pulling, I set my carb and my timing on the dyno under a 55 hp. Just be sure to watch the exhaust temp, a good indicator of timing and fuel, and listen for detonation. It will usually be pretty easy to hear. Iv'e set two tractors like this, and both have worked well. Like I said, though, Just my two cents.
