Chads
Steve M
04-10-2006 16:56:10
Do you plug the line which vents into the air cleaner on the IH's ? Don't quite understand the purpose anyway. I'm running no sleeves in a standard M. i.e. 4 1/8" at 5 1/4 stroke. (281 cid). I drilled the jet and fuel tube as you recommended before. I didn't change the venturi. Probably should go to a 27 ? Any other carb type things you might recommend ?
THANKS !
ChadS
04-10-2006 17:30:19
 Re: Chads in reply to Steve M, 04-10-2006 16:56:10
Sometimes, Or you can run a rubber hose down to the new air cleaner pipe with a fitting if you have a tube coming from the carb. 27 is good, Try to find a cold burning fuel, like E85, little bit of that goes a long way in a Farmall! Burns cleaner, and cooler which makes a bit more HP. is it getting alotfuel at full throttle when you back the adjustment out? ChadS
