NATPA and M-M blocks
The Tightwad Ra
04-10-2006 07:59:04
NATPA does not allow 800 blocks in Div3. I do not see a rule against the larger M5 or G blocks (same bore). I pull a lower powered UB with G blocks localy. Would this be ok in NATPA? I seem to recall similar engines in Div3.
Jerry Cent. Mi.
04-10-2006 13:40:07
 Re: NATPA and M-M blocks in reply to The Tightwad Ranch, 04-10-2006 07:59:04
The G came out with a 6" stroke and the U has a 5" stroke. The U is 283 cubic inchs and the G is 403. That is the difference in the heigth along with the 4 1/4 U bore verses 4 5/8 in the stock G. I really don't know what an 800 block is like.
A.P.
04-10-2006 11:03:12
If I remember correctly, the G blocks are almost an inch taller than the U and even the M5 blocks. The taller height is what is the problem, it allows for a potentially longer stroke or at least a potentially better rod ratio. That is why they don"t allow the use of the 800 blocks as I understand it. I would use the M5 blocks if you can or just be happy to pull your existing tractor engine combination locally.
A.P.
04-10-2006 10:57:35
