Farmall 460 weight help
TWL
04-09-2006 05:32:58
Would any of you have some ideas on how to lighten up a 460?Right now it is at 4700.Press steels on rear,no pump or hydraulics.Any help would be appreciated.
Sheepdog in NE
04-09-2006 20:06:37
 Re: Farmall 460 weight help in reply to TWL, 04-09-2006 05:32:58
You can cut off the back 1/2 of the rear end cover. Look under it and leave the sliding linkage for shifting. Replace with a 1/4" sheet with risers for the bull gears. The steering column can be replaced with tubing and a pipe with 2 beargings 10" apart to hold streeing wheel.
TWL
04-10-2006 16:17:03
 Re: Farmall 460 weight help in reply to Sheepdog in NE, 04-09-2006 20:06:37
Thanks for the ideas Sheepdog.I never thought of those.
TWL
04-09-2006 09:04:46
Thanks Chad,it is the big axle.I do have a 504 front bolster which is lighter than the 460.I am trying to get to 4500lb.I appreciate you help.
ChadS
04-09-2006 05:58:00
Still got that super heavy front bolster under the front? If rules allow, remove it and build a tube wide front end with rack and pinion steering. There is 250# loss in that area. I dont know if Utility, or industrial rear axles fit the row crop rear end housing, but maybe if they did, they would be like the W6 axles on a M to lose a little weight. Light weight seat, if your using the stock front weight bracket, build a custom bracket for the front, put the battery out there if rules allow. Aluminum hood, weld on hubs, Custom air cleaner if your still using the stock oil bath air cleaner, The gas tank in those are pretty heavy, maybe a small tank somewhere. is it a big axle 460 or small axle? Hope this helps, ChadS
