TIRE SIZE
TOWBOATT
04-07-2006 10:59:50
HAVE A AC WITH 14.9X26 TIRES WOULD 13.6X38 TIRES MAKE A DIFFERENCE AS FAR AS PULLING? IS A BIGER OD TIRE BETTER THEN A SMALLER OD TIRER FOR PULLING?
Jeff Oliver
04-07-2006 15:02:10
 Re: TIRE SIZE in reply to TOWBOATT, 04-07-2006 10:59:50
Iknow a guy who did that. he went from pulling up to the 4500# and spinning out to winning most of the time and pulling up to the 5500# and doing real good. He does however have a combine motor in it with a little work done to it.
pullin
04-07-2006 12:33:30
huge difference in your case but you betterhave more power your tire sizes will make a dramatic change in your overall gear ratio,you will run much faster in a lower gear
