Rules Overview - shortened version
Michael Shultz
03-29-2006 05:32:06
I'll give you a basic overview of the rules that may be a little easier to interpret than the website: All weight classes have several divisions - non cut tire, cut tire(tapered cleat, not front cut), 1939 and older, and several different open type classes(turbo, non-turbo, & car engine classics). Every other class is paced (example - 4000, 5000, 6000), while classes in between are non-pace(4500, 5500, 6500, etc.) - reguardless of cut or uncut. We've been doing it this way for about 6 years now and the pull continues to grow. Even the stockers like to open it up and see how fast they can go (most of the 1st timers stall before the 100' mark, but it's all in good fun:). I won't say that it's perfect as it relies a little bit on honesty, but there aren't many people around here that would sacrifice their integrity for a 30 cent ribbon. We don't put an RPM limit on anything - everything is by tire size and cut, pace or no-pace. We use a pace rope that goes approximatley 3mph. The flagman walks the rope, and the tractor's rear axle can not pass the flagman. The flagman will never walk faster than your front tire - if you go 1.5mph he lets the rope slip and walks beside your front tire - limiting "slingshotting" for the stronger tractors to the length of their wheelbase. The non-cut tire class is designed for farm tractors and show tractors - basically a division 1 or 2 NATPA type tractor. The cut tire class is designed for somewhat of a blend between NATPA divisions 3 & 4, but with no RPM limits. We keep the tire sizes small in these classes - 13.6x38 up to 4,500, 15.5x38 from 5,000 to 6,500, 16.9x38 from 7,000 to 8,500, and 18.4x38 the rest of the way up (might be 20.8x38 for above 14,000?).
Open classes can run 18.4x38 tires with any cut all the way up through.
