clutch jd a
jm806
03-28-2006 16:44:07
I have a question about a clutch on an early jd a with 2 frictions. what do you use to hold the power of a big motor with out slipping?
JDTH
03-29-2006 03:45:49
 Re: clutch jd a in reply to jm806, 03-28-2006 16:44:07
Seen the two disk clutches hold over 95 hp, no reason to change.
JDG
03-28-2006 20:16:56
Try the one you have now it may work.Or put a late model pulley on with all the guts. Use your old belt pulley gear.
