Farmall H head
Kevin
03-28-2006 15:11:59
What can i do with my farmall h head to get a little more power? The rest of the tractor is going to stay stock for this season including the old flat top pistons, maybe next year i will go with a stepped aluminum piston. But for this year what can i do to masage as much extra hp as i can with the flat tops and stock cam in there? Ill probly do electronic ignition and all that fun stuff this year if i can too. Anyone know if all the extra goodies for the ignition can be done with a 6v system?
Jared Farmall H
03-28-2006 19:59:50
 Re: Farmall H head in reply to Kevin, 03-28-2006 15:11:59
Not much you can do to the head alone shave the head and that won't do much. I used a 300 head 300 exhaust manifold and a M carb and also had the cam cut that helped our H.P. considerable. Also put in electronic ignition, but you need to be positive ground for it to work.
FarmerSid
03-30-2006 04:52:38
 Re: Farmall H head in reply to Jared Farmall H, 03-28-2006 19:59:50
Jared,
I pretty sure you can get electronic ignition from Pertronics with either positive or negative ground at 6V or 12V.
Cheers!
Sid
