Ideas on farmall c pulling hitch//
t.r.y.
03-27-2006 13:24:11
any pictures or help on ideas for building a pulling hitch for a farmall c
RichH
03-27-2006 19:52:26
 Re: Ideas on farmall c pulling hitch// in reply to t.r.y., 03-27-2006 13:24:11
If a C is the same as a Super C, what more do you want. For stock or hobby stock, with the standard hitch, just shorten it up all the way and put a clevis in the last hole of the channel, or make a flat plate to bolt on the two holes with a 3 inch hole just off the end of the channel. Do you know that on the side where you can adjust the height of the drawbar there is two threaded holes in the casting besides the two holes in the drawbar mount? It also helps to bolt a heavy strap (1/2X2)under the channel with holes drilled to match the holes in the slide area. With it as short as it goes and the height adjustment it's about 18 inches back and 16 to 20 inches high. All I do to go from divI to divII is adjust it up and it works great.
CLIFF S
03-27-2006 15:51:48
Just Come to Buffalo Valley Sunday and you can see mine in person and get a idea or two. Cliff
t.r.y.
03-28-2006 01:03:55
 Re: Ideas on farmall c pulling hitch// in reply to CLIFF S, 03-27-2006 15:51:48
Don't worry we'll be there. We'll have one built by then Last night at about 8;30 its about half was done. any do you pull in 3000 3500 and 4000?? I sure can't wait until sunday. Only wished you could pull oliver 77 in 4500 like any other pull. oh well. see ya, Trent
CLIFF S
03-28-2006 04:29:50
 Re: Ideas on farmall c pulling hitch// in reply to t.r.y., 03-28-2006 01:03:55
There is a pull that you can pull 4500 with the 77! Hughsville at the Lycoming county fair grounds in there back track next to the parking lot oence a month and the first one is April 23 at 11:00 am, My Su C hitch is the stock one but with a D ring to pull from and i also have used what the other guy told you a plate or clevis, Where are you guys coming from ? Theres 5 other Pulling clubs you can pull other than Buffalo Valley, BUT make sure that if you build a drawbar or a plate etc that you are only 18" high and 24 " long from the center of the axle! And yes i pull 3000,3500, 4000lb class. Cliff
T.r.y.
03-28-2006 18:01:16
 Re: Ideas on farmall c pulling hitch// in reply to CLIFF S, 03-28-2006 04:29:50
Where coming from york county below harrisburg. My father inlaw is a dealer/builder for kuhns brothers log cabins. So were up that way often up the the mill anyhow. Our c should do decent in the 3000 and 3500 but the 4000 i don't know because of pulling against wd's and wc's. How is the pull up there at buffalo valley. We can't wait to get there. Were always excited for the first pull of the year. Whats the track like?? how do you pull compared to the other tractors in the class. what do you place? what other tractors pull in those classes? anyhow nice talking to you. If I don't talk to you before I'll talk to you sunday. I drive a tan ford newer style diesel with a gooseneck. I'll have the oliver on my trailer. See ya
CLIFF S
03-29-2006 05:02:32
 Re: Ideas on farmall c pulling hitch// in reply to T.r.y., 03-28-2006 18:01:16
We have done well with the Super Cs My wifes has been the points leader for 3 years until last year when we couldnt make all the pulls and my Super C has won points a time or two in the past, As for AC wc/wd there no threat here most of the time and the track WELL there trying some fresh clay that they were mostly topsoil before So its anyones guess what they will have now, Do you Know Peters with the CASE 200 and 300? there though tractors from your aera. Cliff
t.r.y.
03-29-2006 07:20:43
 Re: Ideas on farmall c pulling hitch// in reply to CLIFF S , 03-29-2006 05:02:32
yeah we pretty much pull all the same pulls local here. what tires do you run on your c's I ran one size over stock because of our local pulls. do you have a front weight bracket?? wwe run stock weights.
CLIFF S
03-29-2006 19:05:29
 Re: Ideas on farmall c pulling hitch// in reply to t.r.y., 03-29-2006 07:20:43
My Super C is a stocker other than an oversize kit 12.4x36 field reddy tires and mid and rear weight brackets But my wifes is a Puller only with 14.9x36 top cut tires the same oversize kit with some extra work that i done to it with a front, mid and rear weight brackets and no hyd arms etc, whellie bars, Like i said a pullin tractor. Cliff
t.r.y.
03-30-2006 04:17:31
 Re: Ideas on farmall c pulling hitch// in reply to CLIFF S , 03-29-2006 19:05:29
SO do you pull your wifes in the stock class or modified?
t.r.y.
03-30-2006 07:16:53
 Re: Ideas on farmall c pulling hitch// in reply to t.r.y., 03-30-2006 04:17:31
one other question what classes are you allow suitcase weights and brackets. by what you said before about your brackets I would imagen suitcases are legal in all classes. thanks cliff
CLIFF S
03-31-2006 07:36:35
 Re: Ideas on farmall c pulling hitch// in reply to t.r.y., 03-30-2006 07:16:53
Weights and Brackets are used in all classes and her super C pulls in 3.5 Mph class the same as mine at B V where they are the only place they dont seporate tires that we pull, See you sunday. Cliff
