diff between 450 and m carb?
cowboy red
03-26-2006 21:08:18
what is the difference between the 450 and m carb other then the size of the venturi?
ChadS
03-27-2006 06:08:09
 Re: diff between 450 and m carb? in reply to cowboy red, 03-26-2006 21:08:18
The idle passage and idle screw location. The 450 has the adjustment in the carb flange like the 6 cyl carbs. the old M, uses a larger brass screw located at the mid base of the throat of the carb. The new carbs crack internally and the idle is affected. The older carbs are preferable, Hope this helps Chad
cowboy red
03-27-2006 08:52:39
 Chads in reply to ChadS, 03-27-2006 06:08:09
thanks for your help, what is you website because i need a governor spring and advanced timing kit for a delco distributor (i havent looked at it yet).
thank you
ChadS
03-27-2006 13:48:33
 Re: Chads in reply to cowboy red, 03-27-2006 08:52:39
www.thetractorshop.com Vertical mounted distributor??? if so, they dont need anything changed, just make sure its working and tight. they use a light weight advance and light springs VS IH distributors. ChadS
cowboy red
03-27-2006 15:45:43
 Re: Chads in reply to ChadS, 03-27-2006 13:48:33
Yes my delco is an upright. what is the best times to call you when your not busy (even though your probably always doing something haha).
mohead10
03-27-2006 17:31:25
 Re: Chads in reply to cowboy red, 03-27-2006 15:45:43
Cowboy Red please don't waste your money.I got one of chad's magic springs for 25.00.I took this thing and put it on a scale to test pounds,I measured it every way I could.then I took A trip to my hardware store.I got 2 for 1.99.
ChadS
03-27-2006 17:43:58
 Re: Chads in reply to mohead10, 03-27-2006 17:31:25
Thank you for your patronage. Well, email him with the info on where ya got it, or post it, I cant stop ya, nor will I. Also, someone else tried copying it, called it an original,, must be doing something right,,, aint I? ChadS
ChadS
03-27-2006 17:09:52
anytime during the day. ChadS
