msd box
msd
03-26-2006 00:56:36
I've read about 250 of the 500 posts on msd boxes thanks to all you guys. What a got from it was that to use the points instead of the electronic igntion cause it would be cheaper and that the electronic ignitions can get fried and all they do is trigger the msd boxes anyway. I was wonderin how long the boxes last and if you thought it might be ok to get a used one, or just get a new one. Also what coil would be best for it. I was thinking about the msd blaster2. please give any info and correct me if i understood something wrong.
thank you
superih
03-27-2006 05:35:22
 Re: msd box in reply to msd, 03-26-2006 00:56:36
If you use points, don't use the condensor.
Josh Hannah
03-26-2006 18:16:02
Not all coils are compatable with the MSD boxes check the coil list in the directions
eastcoastpuller
03-26-2006 12:24:38
will the same msd box work for 4,6 and 8 cylinders. or are they made for each one.
msd
03-26-2006 12:53:43
 Re: msd box in reply to eastcoastpuller, 03-26-2006 12:24:38
they will work for 4,6,8 cylinders and i read about guys putting them on jd g's so i guess they might for for 2 cylinders also.
msd
03-26-2006 10:27:45
thanks alot!
ChadS
03-26-2006 08:45:18
Point contacts work just fine to operate MSD. The coil output no longer passes thru the point contacts so no points to burn up. Just make sure the mechanical advance in the distributor is working, it can throw the MSD off and cause a pop thru the exhaust, or the intake. Bout any coil is good from here on out with MSD,, I like Accel super stock coils, Ive had MSD coils go out before, never had trouble with accel. Once the MSD system is installed, throw out the book specs on the plug gaps, you can open em up to .050 minimum and have a nice flame to the electrode. the electronic conversion dont amplify the coil out put when MSD is used, so there is no better setup as far as the trigger is concenerd. The MSD uses all the coil"s potential power, just like a electronic conversion does,, but instead of 1 fire from the electronic, or points you get 3 to 5 sparks at once to give the cyl alot better and more complete burn in the chamber. 6AL are great to start with, then go from there. Hope this helps, ChadS
Dave in MN
03-26-2006 08:05:02
If your points/dist are in PERFECT condition, you probably won't see much differance. Mine were 50+ years old with lots of hours on them, I saw a marked differance in performance. I am not useing a MSD box, just a hot coil with plugs gaped at .045.
mlpankey
03-26-2006 03:05:53
if the box fires its good . used boxes are usely half the price of a new one . i teend to to use 6t box due to vibration . blaster 2 coil
msd
03-26-2006 13:56:01
 Re: another question in reply to mlpankey, 03-26-2006 03:05:53
what gap should the points be set at. and chads, which super stock coil did you get? the 42K volt or 45k volt?
thanks for all you help, just bought a 6 al today.
ChaDs
03-26-2006 17:38:43
 Re: another question in reply to msd, 03-26-2006 13:56:01
Its not the large diameter coil it looks like a regualr 12 volt coil, chrome, or yellow. I think its the 42, Chad
