M perfection/ moto-plex indoor pull] april 7-9
k.p.banet
03-22-2006 17:44:01
Call me again if it was you, lost you phone # wife forgot to save it.call up to 10:15 at night. kevin {We are pulling indoor april 7-9 at LAOTTO IN.}
AC
03-23-2006 16:15:20
 Re: M perfection/ moto-plex indoor pull] april 7-9 in reply to k.p.banet, 03-22-2006 17:44:01
Is a 400 LP manifold legal on a 400 gas in farm stock?
B BARENIE
03-23-2006 17:58:34
 Re: M perfection/ moto-plex indoor pull] april 7-9 in reply to AC, 03-23-2006 16:15:20
THE MANIFOLD IS LEGAL, NOT THE HEAD !
Also, that hot l.p fuel is illegal also !
Please use original I.H. studs, when installing the manifold.
Do not grind off the casting numbers!
That manifold should give you an extra 82 h.p.,
at 7200rpm !
AC
03-24-2006 04:19:40
 Re: M perfection/ moto-plex indoor pull] april 7-9 in reply to B BARENIE, 03-23-2006 17:58:34
Well Bud, that shouldn't be a problem, at 7200 rpm, because I have already been dyno-ing it at about 9200, at which time, it is beginning to float the valves just a bit, but thats ok, because I will install double valve springs with 600 lb seat pressure. Oh, and it is a gas head, not an LP head. Hot LP fuel? I haven't tried any of that, because the sun hasn't been out too much here in sw Michigan to warm it up...!!! hope to see ya out there this year...Andrew
K.PBANET
03-23-2006 18:54:01
B.BARENIE IS NOT GIVING A RESPOUNCE TO OUR CLASSES AT MOTO-PLEX ,BUT TO THEIR LOCAL RULES IN HIS CLUB.
B BARENIE
03-24-2006 15:52:37
 Re:KP in reply to K.PBANET, 03-23-2006 18:54:01
K.PBANET
WAS GIVING AC A LITTLE HECKEL !
DID NOT MEAN TO CAUSE ANY CONFUSION !
SINCERELY APOLOGY
BUD BARENIE
k.p.banet
03-25-2006 18:39:47
 Re:KP in reply to B BARENIE, 03-24-2006 15:52:37
NON TAKEN!!
k.p.banet
03-23-2006 16:50:18
YES on 400-lp.
AC
03-24-2006 04:20:46
 Re: M perfection/ moto-plex indoor pull] april 7-9 in reply to k.p.banet, 03-23-2006 16:50:18
ok, thanks Kevin..
We tart ED
03-23-2006 16:40:49
How about some more stupid questions for you Kevin.Can I run NGK spark plugs,can i cut my tires with a chainsaw?Is AC related to ChadS
AC
03-24-2006 15:24:30
 Re: M perfection/ moto-plex indoor pull] april 7-9 in reply to We tart ED, 03-23-2006 16:40:49
Hey, I'll be down there hopefully with a farmall 400 with a bent muffler. Either way I'll be there. Come and say hi. It would suprise the heck out of me, because I bet you wont do anything but stay on YT and run your mouth..
I just needed to know, so I could put the old manifold back on...don't want to be a cheater... :) ..... .Andrew
ChadS
03-25-2006 07:51:52
 Re: M perfection/ moto-plex indoor pull] april 7-9 in reply to AC, 03-24-2006 15:24:30
Andy, he would be the one giving you the bird cause you out pulled him. ChadS
AC
03-25-2006 11:38:42
 Re: M perfection/ moto-plex indoor pull] april 7-9 in reply to ChadS, 03-25-2006 07:51:52
Yeah, there is at least one sore loser / moran in every crowd. How come they alllll find me??? :) Andrew
ChadS
03-25-2006 15:01:49
 Re: M perfection/ moto-plex indoor pull] april 7-9 in reply to AC, 03-25-2006 11:38:42
Cant say why that is. I hope they dont keep this up,, Something Wilder might hear it, and have to be risen out from the corner shop bay. I seen you had the 6 inch H, did you get it swinging in there? What are you missing to finish it up? Id like to see that one running! If your H is still running, put it back in farm stock in our club! No one call ya cheater there! It was shocking to see the great H like that in the shop when you visited last?? Only H farmall i know that has out pulled 3 UB Molines in one day in 3 classes, DISTANCE WISE back in its hayday. Picked on, protested, boycotted meanest H I ever saw. I just picked up a real nice M, I may have to fire up the semi to get em all there this year. I have to do up another block for the H, sold the other I had ready, I got a 350 block with a busted sleeve that will work out. Will that bored out 350 block I got do you any good? Email is open. Chad
