WD 45 desil
Bob Allis in Wi
03-22-2006 02:55:41
Is it leagal to run a desil rear end with a gas engine? I know the desil was geared slower and might help with 38" tires.
SPT
03-23-2006 06:13:07
 Re: WD 45 desil in reply to Bob Allis in Wi, 03-22-2006 02:55:41
Mate it with an Ollie.
Kip[UT]
03-22-2006 08:34:06
This is a legal undetectable change & would make sense on a puller w/ taller tires, esp. if you are dealing w/ speed limits, allowing higher rpm w/ slower ground speed. Same reason WC pullers like to use RC gears in their rear ends. I know a guy with a gas rear end in his 45 diesel & boy is it a race horse!
Joshin Around
03-22-2006 05:31:58
Why do you wanna slow down? .. Speed up!
Joshin Around
03-23-2006 09:31:53
 Re: WD 45 desil in reply to Joshin Around, 03-22-2006 05:31:58
I didnt wanna come off like a jerk. The Diesel rearend is slower than a WD45 Gas. I beleive that a WD with 38's runs about 3.2 mph in first gear im not sure mph on the Diesel .. Maybe if your engine is strong enough you can run 2 gear at low RPM's.
