wc starter
charley arms
03-20-2006 05:57:27
i would like info on converting my 42 wc to key start instead of the push lever
or is this something best left alone
also i am seeking 38" wheels with 6 hole centers for my puller
Joshin Around
03-21-2006 08:53:23
 Re: wc starter in reply to charley arms, 03-20-2006 05:57:27
I would leave the starter alone .. the 38inch tires is going to be your problem. I have a WC myself and I have been looking for tires for a long time. your best bet is to find a set of 9 bolt wheels and have a machine shop make you a set if adapter plates. I saw a few WC's at Tunica last year with adapter plates looked like it works well.
charley arms
03-21-2006 14:40:53
 Re: wc starter in reply to Joshin Around, 03-21-2006 08:53:23
thanks for the info i saw a wc at a pull last year and he had key start on it
he said it was a 46 but i don't know how he did it
i know what you mean about the wheels
Chum
03-21-2006 16:59:59
 Re: wc starter in reply to charley arms, 03-21-2006 14:40:53
Charley- Take your starter to a rebuilder and have him remove the copper pad that is under the switch and replace it with a stud. Then, put a solenoid on it with a key switch with a start position and wire it up accordingly. If you don't understand this, email me back and I'll draw you up a sketch. Good luck. Chum
CHARLEY ARMS
03-23-2006 06:58:33
 Re: wc starter in reply to Chum, 03-21-2006 16:59:59
THANKS
WHEN I GET ALL THE OTHER STUFF DONE I'LL TRY THAT
