pistons for 630 JD
frank in PDL
03-19-2006 15:11:09
I have a 1958 630 gasoline tractor which does not have but only 75 psi.per cylinder, The book says it should have 132 psi.We use the tractor at tractor pulls I want to rebuild it, and was wondering if I decide to put new pistons in what is the best brand and what compression ratio to go to without having to bore the engine?
Thanks in advance,
Frank in PDL
JD hauler
03-19-2006 17:24:40
 Re: pistons for 630 JD in reply to frank in PDL, 03-19-2006 15:11:09
Frank, go with 620 or 630 LP pistons in your bore size, you may have to bore if its out too bad, but those pistons will help a good bit.
