Interesting info
MN JD
03-18-2006 18:42:14
Talked to a gentleman today that has worked on John Deeres for about 50 years. Got talking about rpms in the 2-cylinder JD. He said that if an 830 was to run wild, at about 2800 rpms the flywheel will start to come apart, due to the weight and makeup of the flywheel and centrifugal force. He told me that a John Deere engineer told him the figures, from test they had done at the factory.
Just thought that was kinda interesting.
LW
03-19-2006 06:12:13
 Re: Interesting info in reply to MN JD, 03-18-2006 18:42:14
And that was with a new well fitting flywheel, It wouldn't take that much if you had some play were it fits the crank or a small crack some where.
MN JD
03-19-2006 07:26:03
 Re: Interesting info in reply to LW, 03-19-2006 06:12:13
On a new tractor in the factory.
