Farmall M plugs
Hank L
03-18-2006 17:57:07
I am using champion D-16 plugs in my stock M. I am constantly having to change them for the tractor to work decent.Everything else seems to check out.Any suggestions on a different plug I could try, maybe something a little hotter.Wht kind of plugs are you guys using on stock M,s. Hank
Robertw
03-20-2006 12:55:28
 Re: Farmall M plugs in reply to Hank L, 03-18-2006 17:57:07
I run D21's champions in my farmall super h they work good so far a lot beter then the D16's there a little hotter plug. I was told by the IH dealer the reason was because of todays gas is different than the old days when these tractors were built.
Robert from mich.
supermpuller
03-18-2006 18:12:56
386 autolites
the preacher
03-18-2006 18:17:25
 Re: Farmall M plugs in reply to supermpuller, 03-18-2006 18:12:56
I was running D-16's in my MH, and switched to Autolite 386's. Worked a lot better. Less fouling, better starting. An electronic ignition helps also, if the rules allow you to have one.
