block swap in a us g
freebird
03-16-2006 19:00:35
WHAT ALL DO YOU HAVE TO CHANGE TO PUT A STYLED BLOCK IN A UNSTYLED G. THE BLOCK IS SHORTER, KEEP THE FLAT HEAD. WOULD THAT BE TO MUCH COMPRESSION.JUST WANTING A LITTLE EXTRA THUMP AND TO KNOW WHAT ALL HAS TO BE DONE TO COMPLETE SWAP
DSK
03-17-2006 16:41:59
 Re: block swap in a us g in reply to freebird, 03-16-2006 19:00:35
I did such a swap on a late US G {41} years ago. You will have to drill new holes in the bottom of the frame where the 2 block attaching bolts go through. You will also have to shorten the pushrods about 3/4 inch. If it is an early US G, you will also have to use the late US upper water pipe. As for compression, if you are running a M&W style piston, you will have to mill about .400 off the tops to keep your c.r. under 10:1.I recommend a minimum of .800 between the top of the piston and the head surface on G's set up like this. You will also have to run 100 octane gas or better. Mine always worked well with avgas 100.
