stroking ac wd45 eng
yorkie
03-16-2006 13:58:53
can any one explain the stroking process to me or where can i read about crank is re welded and longer rods needed to be made
mlpankey
03-16-2006 20:29:47
 Re: stroking ac wd45 eng in reply to yorkie, 03-16-2006 13:58:53
most offset grind the cranks to a smaller rod journal size . this eliminates the need of welding on the crank. selection of a piston with a different pin height takes care sometimes of rod lenght issues .but keep in mind the rod journal that the crank is ground to needs to be readily available. also on a allis theres quite enough room to move the piston up in the block adding compression which also helps in power as much as cubic inches.
