carb modifications
moli
03-16-2006 05:18:06
Almost done with my 448 cid U Moline and was woundering about what carb work needs to be done..Its the short block,U rod,m 670 propane intake n exhaust manifold with 4210 heads.(4.8x6.180) Everything is only going to be matched to the gaskets with a little bigger cam cut for torque and lugging.. Stock valves with tripple angle valve job..Its going into div 3 @ 20% over rated rpm..Im not porting and polishing and getting things bigger cause i want to keep my intake velocity up for the lower RPM.I would like to use my U carb and mod the internal parts.. But not sure what needs to be done..any and all ideas please.....STEVE
b barenie
03-17-2006 20:38:12
 Re: carb modifications in reply to moli, 03-16-2006 05:18:06
might take a look at a (g) carb
b barenie
03-17-2006 20:37:09
call Lawerence Wilson (old power pride publication) Also paul marrlet (marrlett competion) can help you out !
Very good common sense on the build up !!
hope this helps
