ih clutch
jm806
03-15-2006 17:28:43
how much horsepower will a 14" 8 large pad clutch with 15 spring pressure plate hold? thanks.
856 puller
03-16-2006 15:49:39
 Re: ih clutch in reply to jm806, 03-15-2006 17:28:43
we had a hi-capacity 14" hd with strongest springs they had it worked ok i think it had 12 pads. the flywheel step had to be perfect or it would not releace all the way. that was in 8500lb 3rd hi 400ish hp. we ended up with a steel double disc set up
mdp
03-16-2006 05:34:01
depends on what gear you want to pull. i had a 1206, dyno'ed @ 375 hp, w/14" clutch, pressure plate had h.d.'puller'springs (black) and 12 pad disc. tractor would hook up fine in 2nd hi, but 3rd hi on a tight clay track i couldn't get off line (note: all parts were new). i added 10 h.d. die springs inside of pressure plate springs, was barely able to reassemble plate and when installed in tractor was all i could do to push clutch w/both feet. lower clutch rod on clutch pedal to increase mechanical ratio, pushed like a stock clutch, held 3rd high.
