Making an IH 263 a 301
superhooker
03-14-2006 20:25:48
What machining is required to make a sleeved C263 accept C301 pistons? What do you guys do about the void in the block where the sleeve flange was? Thanks for any and all info.
es
03-15-2006 17:06:17
 Re: Making an IH 263 a 301 in reply to superhooker, 03-14-2006 20:25:48
you can bore the 301 out to 4"
J-Garst
09-27-2006 18:24:30
 Re: Making an IH 263 a 301 in reply to es, 03-15-2006 17:06:17
If you bore a c301 to 4" it is about a 50/50 chance it will brake through. If you are successful you need to hard block it all the way to the top. I've been there!
superhooker
03-15-2006 17:09:48
Do you know of a 4" piston that will fit the stock rod?
es
03-15-2006 23:46:55
 Re: Making an IH 263 a 301 in reply to superhooker, 03-15-2006 17:09:48
ross pistons they are 100.00 a peice 80.00 for rings
Mcred
03-16-2006 06:51:02
 Re: Making an IH 263 a 301 in reply to es, 03-15-2006 23:46:55
How do ya get ahold of ross pistons I may even be interested in them?
es
03-17-2006 16:16:42
 Re: Making an IH 263 a 301 in reply to Mcred, 03-16-2006 06:51:02
ross pistons 1 310 536 0100
superhooker
03-15-2006 16:47:00
Thanks, Farmall Daddy. I bought a 301 LP motor from a 806 and planned to put it in my 560 (which is stuck). When I tore the 301 apart, I found it had been bored .60 over already and the cylinder walls were pitted so I guess that block is junk. I guess I"ll bore the 263 to accept 301 pistons and use the 806 cam, governor, and LP cylinder head and manifolds. It should wake that old 560 right up!
AC
03-16-2006 03:52:32
 Re: Making an IH 263 a 301 in reply to superhooker, 03-15-2006 16:47:00
Are 4 of those LP pistons salvageable? If so, I'd be interested in them...Andrew
superhooker
03-16-2006 17:00:17
 Re: Making an IH 263 a 301 in reply to AC, 03-16-2006 03:52:32
That 806 lp engine had been bored .60 over and standard firecraters installed I think. The # on top of the piston is 392828R2.
AC
03-17-2006 14:50:45
 Re: Making an IH 263 a 301 in reply to superhooker, 03-16-2006 17:00:17
What do you want for them? .....AC
Farmall Daddy
03-15-2006 05:42:35
I took my '62 560 from a 263 ci out to a 301. All I did was bore the block from the original 3 9/16 piston out to the 3 13/16 which comes out to be boring the block an 1/8" on each side which will bore the block to a full 1/4" when your done with it. My pistons were bored right to the block for a tight fit due to we didn't know how close the water jackets were. My 560 dyno'd 81 horse with just the pistons put into the block. Since then, I had new valve guides put in, and the head was trued up, and on a good day, I'm guestimating it should turn aroun 85-88 horse. Hope this helps, and good luck!!
