How do i make a good JD B Puller
Chassis Klatt
03-14-2006 14:14:51
Are there any tricks and tips out there for a B.
What are the main points to do make a good B puller. What would you sugest buying to make a good tractor.
Chassis Klatt
03-19-2006 19:51:42
 Re: How do i make a good JD APuller in reply to Chassis Klatt, 03-14-2006 14:14:51
Same thing with the b about making a good puller but with An A john deere
Thanks for all the tips guys appreciatit.
MJF
03-16-2006 18:45:49
 Re: How do i make a good JD B Puller in reply to Chassis Klatt, 03-14-2006 14:14:51
why would you want 14.9's on a B, I guess it's possible to spin out if it's a staight 6 trans. I think the run about .02 mph. We have A's here on the farm that have 13.6s and 14.9s, I bet that B looks terrible with them tires but thats my opinon
Rekabnivek
03-15-2006 16:23:51
I pull a '39 B. The best thing that I have done (inexpensively) was get a gas manifold from Detwilers and have they port and polish it. Also make it as light as possible so you can put the weight where you need it. I pull my B in the 3000 Lb class. It took a little work to get it down that far, but it pulls competitively.
farmallkidinPa
03-15-2006 12:28:55
i have a 41 JD B a farmer gave me and the only thing changed was the rear hubs are not factory and i can spin mine out in 4200 most everytime only time it wont is on a really tight wet red clay track, even on a track like that it reall paws and nearly slips
jd b puller
03-15-2006 07:41:25
Displacement Displacement and more Displacement. And remove everything that you don"t need.
And check your e-mail.
lots of money
03-14-2006 19:24:41
sorry but true
Joshin Around
03-14-2006 14:22:06
I have a friend that pulls a John Deere B Havent done a thing to it but change the oil, set the valves, clean the carb, and set the timing and he spins out in the 4200 with 14.9 tires.
unknow puller
03-15-2006 04:35:10
 Re: How do i make a good JD B Puller in reply to Joshin Around, 03-14-2006 14:22:06
your friend is not telling you the truth about his b
Chassis Klatt
03-15-2006 14:06:38
 Re: How do i make a good JD B Puller in reply to unknow puller, 03-15-2006 04:35:10
why do you say that.
Joshin Around
03-15-2006 17:28:38
 Re: How do i make a good JD B Puller in reply to Chassis Klatt, 03-15-2006 14:06:38
I know that it is the truth .. I helped him pull it out of a barn in north east Georgia, and it sets in my shop so everything that is done to it .. I do.. I know that it is THE TRUTH!
