450 block
Devin M
03-13-2006 17:04:01
what is the bore on a 450 block. what is the max u can bore a 450 block to? I ask this because i was talking to a guy that has a set of pistens for a farmall m thay are 4.3 inch bore and i was wondering if i was beter off to put them in a 450 block? or bore an m and put them in it. Is their a block that well work better.
B BARENIE
03-13-2006 19:21:58
 Re: 450 block in reply to Devin M, 03-13-2006 17:04:01
A GUY TOLD YOU SOMETHING, YOU SPEND MONEY, IT DOESN'T WORK, WHO'S TO BLAME !
THEIR IS NOT A 264 BLOCK OR A 281 BLOCK THAT YOU CAN GUESS AT. !
YOU MUST HAVE A BLOCK (SONIC) TESTED TO SEE WHATS LEFT AFTER MANY YEARS OF CORRISION OR RUST DECAYING, TO SEE IF YOU CAN BORE THE BLOCK !
A 4.30 BORE SHOULD GO IN MANY C-264 BLOCKS AND C-281 BLOCKS BUT THEY HAVE TO BE TESTED !
WHAT STROKE DO THESE SPECIAL PISTONS FIT ?
WHAT COMPRESSION RATIO ? WHAT RING SET-UP !, WHAT TYPE OF MATERIAL !
GO SLOW !
RichH
03-13-2006 18:03:11
I put a set of 4.25 M&W pistons in a 450 block that all I did was hone the bore smooth. I was going to put them in an M block, but as # 1 bore was just about to the right size we struck water. At least alot of time wasn't wasted on any more boring. I would think with a good 450 block 4.3 would be possible. Just my .02.
