JD A and 60 block difference
Deeretrax
03-12-2006 06:09:52
I recently ripped into a John Deere A(late model). I came across a deal for a John Deere 60 with a new block and head not long before it was parked. What is the difference? I was wondering if I could make it work by swapping them. What else do I have to do? Will the block bolt on? Thanks in advance!
G/MAN
03-12-2006 14:05:37
 Re: JD A and 60 block difference in reply to Deeretrax, 03-12-2006 06:09:52
The late "A" and "60" blocks are completely interchangeable, and the "60" block became the service block for the "A". Deere still had these units in stock into the mid-90s, and there are probably a few NOS ones in dealer stock to this day.
Paul in Wi
03-12-2006 06:21:23
If it is truely a '50-52 A then the block will bolt right on. I think the heads are different,and for sure the 2 barrle carb. and intake manifold on the 60 are different, but you could maybe use these on your A with a little work.
