John Deere 4010 engine swap
Deeretrax
03-12-2006 06:05:30
I am looking at a John Deere 4010 with a blown deisel motor.I am really unsure about the year. I was wondering what is the biggest engine I could put in it? I really don't want to go through to rebuild the old one, especially if I use it for pulling. Thanks in advance!
G/MAN
03-12-2006 14:17:50
 Re: John Deere 4010 engine swap in reply to Deeretrax, 03-12-2006 06:05:30
The biggest "stock" Deere engine that will fit in the frame? The 6081 used in 8000 and 8010 tractors, combines and a slew of other Deere machines. Similar external dimensions, bolt patterns and so forth to the stock 4010 engine, but with 496 cubes. It won't be a "bolt-in" by any means, though, apart from physically fitting in the frame, as the accessory drives and so forth would be very different - for the water pump, alternator, etc. Of course, thinking that stock 4010 guts are going to live for very long behind one is being pretty optimistic. As 4010 said, WTW is the guru around here when it comes to Deere engine swapping...
4010
03-12-2006 07:26:54
You need to post/look on here or the John Deere site for WTW. He is very knowledgable in the question your asking. Have heard a 466 will fit with a few modifications.
