smaller front wheels
Kevin
03-11-2006 16:25:27
What are all the effects of putting smaller front wheels on a tractor? I understand they weight less but will the front end sitting lower make the front heavier or wont it change the balance much?
Kevin
03-12-2006 05:50:42
 Re: smaller front wheels in reply to Kevin, 03-11-2006 16:25:27
So is this a good thing to do even with wheelie bars? Or is this more less a precationary thing for people without wheelie bars?
Sorry, im not much of a geometrical person, so i have alot of learning to do so i can balnce my tractors good.
Dave in MN
03-12-2006 16:58:18
 Re: smaller front wheels in reply to Kevin, 03-12-2006 05:50:42
If you are going to pull more than 1 time, GET THE WHEELIE BARS PUT ON!!!!
On my tractor, I have 18.4X38's on rear so the front end is quite a bit lower looking than stock.
I think that where you pull on track (left or right a couple of inches), what kind of tires/type of tread, height and distance back of axel hitch and where you have your weigts placed on tractor (front, middle or rear) will make a much bigger differance in your pull distance than if you have small tires on the front.
Dave in MN
03-11-2006 18:20:23
It will give the front end that much more room to rise before it goes over the center plane. I don't know that it makes that much differance, but every little bit helps! I have mine that way mainly because I got car spare "doughnut" tires free instead of having to buy the regular ones.
