compression jd a
jm806
03-11-2006 13:21:34
I have a jd A that is bored and stroked with about 200psi at cranking speed.what would be the best octane fuel to run in this tractor?
champspa
03-11-2006 16:07:56
 Re: compression jd a in reply to jm806, 03-11-2006 13:21:34
I have a friend with 200psi in a G . he has to run aviation fuel to get the most hp on a dyno
BUDD
03-11-2006 15:43:09
jm806
It is this simple (and not trying to be a smart a$$) you want to use the lowest octane that you can get by with and not have any pre-detonation. I would guess that you will need at least 100+, but that is just a guess.
BUDD
dctom
03-11-2006 16:16:29
 Re: compression jd a in reply to BUDD, 03-11-2006 15:43:09
is that why you use 130 av gas budd??? lol tom
Drew
03-11-2006 19:15:28
 Re: compression jd a in reply to dctom, 03-11-2006 16:16:29
Is that 130 Octane number 'reserach octane', 'motor octane' or the average 'r+m/2'? Standard pump gas, 87 octane for example, is 'r+m/2'
BUDD
03-11-2006 16:44:54
dctom
Nope just "pump gas" (";")
BUDD
