Piston clearence
Jumpin Jim
03-09-2006 14:24:48
I have a question about piston to cylinder head clearence. My pistons are sticking out of the block .020. My head gasket is about .055 thick crushed. I know that should clear my concern is my pistons will be partly covered by the head. My combustion chamber is smaller than bore. The pistons will have about 3/4 of a inch covered on each side. Will this get a clean burn this way? thanks Jim
B BARENIE
03-11-2006 22:09:31
 Re: Piston clearence in reply to Jumpin Jim, 03-09-2006 14:24:48
NO !
PLEASE LOOK AT MOST OF ALL COMBUSTION CHAMBER DESIGN, IN THE AUTOMOTIVE WORLD !
ARE YOU WORKING ON A TRACTOR, OR A CAR !
Greg_Ky
03-10-2006 13:27:26
Don't forget to check valve to piston clearance.
Crutch
03-09-2006 18:50:53
Squish, quench are as you are talking about is free mechanical octane in a manner of speaking. The areas no greater then .045 send a high speed jet of turbulent mixure toward the combustion chamber. This mixing eliminates lean pockets which will detonate, the piston stays cooler in these areas which impeads pre mature detonation. The high speed mixture makes a faster burn which allows you to run a few degrees less timing.
Most people go zero deck clearance and use a thinner gasket but your way should work in a pinch. Longer rods expand/stretch more and when the piston rocks over at TDC you might be a little closer then you think. As long as you are not turning a lot of extra RPMs you should be ok.
scotc
03-09-2006 17:33:26
i don't know about a deisel but on a gasser it should get you more power. According to Richard Ehrenberg S.A.E.(magazine writer) the fuel will actually detonate at higher rpm where the clearance it tight and will thus speed up combustion because the flame doesn't have to travel solely from the spark plug, resulting in more power. Of course that's just my interpretation of what that article about the chrysler smallblock magnum-head-on-an-la-series-engine said.
