W9 carb
JP JONHSON
03-08-2006 14:32:51
Can anybody out there tell me how far you can bore out the throttle body of a W9 carb?
thanks, JP
mdp
03-11-2006 08:56:20
 Re: W9 carb in reply to JP JONHSON, 03-08-2006 14:32:51
w9 carb is 1-9/16 throttle i.d., can be bore out upwards of 1-3/4", but you will ruin the idle circuit (transfer port @ throttle edge), will run, but causes rough idle w/lots of black smoke. save your w9 carb for a excellent stock to mild performance carb (will add 5-9 hp on stock m), start with a 300-450 carb, can bore oversize and idle will be ok as idle port is @ mount flange. i've bore several carbs out, including through venturi bore, then i custom build venturi, also need enlarged jet & fuel discharge tube (IH# 384024R1, for 806 gas). email me if you want more details
