Pulling cam and head on farmall H
Kevin
03-07-2006 18:29:52
Ok ill admit it, im lacking of some knowlege i could greatly use here. I think i got the head all ready to pull off but what about the cam? Is there anyone with enough patients to give me a good step by step procedure for this to make sure i didnt miss nothing? I would greatly apreciat it as this is my first time breaking into a tractor motor myself, normally i send em away but i want to save some money on this one. Dont want to make my first one a bad experience. Thanks
Kevin
FatRedneck
03-08-2006 07:34:14
 Re: Pulling cam and head on farmall H in reply to Kevin, 03-07-2006 18:29:52
just use common sense, it is nothing to be scared to do first, remove the exhaust
then, the water jacket
the oil line next,
hopefully the valve cover is off by now remove the rockers and pushrods
then skematically loosen the head bolts
take em off if the stud and all comes out dont worry it can be installed that way later
take the steering shaft out remove the head for the cam just take the side panel off the side of the engine and take out the cam i suggest yu use a fishing tackle box to segregate all your hardware and make sure ot label where the came from.
good luck and have fun!
Buzzman72
03-10-2006 07:21:11
 Re: Pulling cam and head on farmall H in reply to FatRedneck, 03-08-2006 07:34:14
Now, maybe I'm not as smart as some of y'all, but the only way I can figure out to take the cam out of a Farmall H from the SIDE of the engine is...IN PIECES. I mean, how are you gonna get the timing gear--which is bolted to the cam on the FRONT of the engine, under the TIMING COVER--loose from the camshaft WITHOUT removing the timing cover...which also requires removing the crank pulley, best I can figger?
Of course, like I said, I ain't the brightest Crayola in the box, but it would appear to me that, unless the cam will clear the bolster support after removal of the radiator, the best bet would be to support the engine at the bellhousing, unbolt the side rails and roll the front end assembly away, and then pull the cam out from the front.
But then, I'm just like my dad, who always said he was born stupid and lost a little bit of ground every day. When you take that cam out through the side of the block, can you take some pictures so a dummy like me can understand how you did it? 'Preshadit.
