52 'A' rpm
Dane in PA
03-06-2006 17:45:32
Just got done changing the tires on my 1952 A, so I got it out and checked the RPMs with the new hand held tach. she read about 1300 RPMs so I figured that is about 33% over factory. Guess I'll have to tame it down a little bit for the upcoming pulls, that is if I wanna play fair :) what do you guys think
Dane
Mike n Mo
03-06-2006 19:30:20
 Re: 52 'A' rpm in reply to Dane in PA, 03-06-2006 17:45:32
Most clubs that limit RPMS use the high idle spec. An A is spec'ed for 1080 (some use the G spec of 1115), so you're in the neighborhood of 20 percent over instead of 33 percent. What do your clubs/pulls allow?? Mike
Dane in PA
03-07-2006 03:51:54
 Re: 52 'A' rpm in reply to Mike n Mo, 03-06-2006 19:30:20
they usually allow 10% over. But I have yet to see them check, as they are friendly neigborhood pulls.
jdlover
03-08-2006 04:52:41
 Re: 52 'A' rpm in reply to Dane in PA, 03-07-2006 03:51:54
they wont be friendly if you are runnin @ 1300 r.p.m.Believe me someone will know by sound alone,its not hard to tell when someone is over by 300 rpm's on a A or a G.
