Massey 101 RPM
Scott Mc
03-06-2006 15:29:16
I'm building a 251 Chrysler. I wonder if anyone can tell me what maximum RPM this engine can stand and sustain.
Lee Werth
03-08-2006 07:14:08
 Re: Massey 101 RPM in reply to Scott Mc, 03-06-2006 15:29:16
o i almost forgot i run 6400 rpms my cam is done by bary cams in MN and its got duration it shaking the tractor at 1000 rpms and hes right shes got wind just hold on
Lee Werth
03-08-2006 07:08:17
i pull a super 101 i did every thing known to do to a 251 the biggest prolbem with getting rpms is getting enough air to the motor i ran a down draft maniflod and a carter one barrel you got to open the manifold way up lots of grinding and polishing as for the head i run a cast spitfire head its all about the CCs so take the head to a shop and have the find out the CCs of it and i run chevy small block valve springs it takes a little work to do it any guestions let me know
Former Wards Puller
03-06-2006 22:02:24
Years ago I used to pull a Wards ER with a 250 Chrysler.It had a 265 crank and was bored .125 with Jahns 10-1 pistons.It had an Isky 3/4 cam with heavy valve springs plus factory dual 1 bbl carbs and dual exhaust.We turned it 6000-6200 all the time.
I've seen some 101 MH pullers crank their little 230's up around 7000 rpms.
ChadS
03-07-2006 12:41:19
 Re: Massey 101 RPM in reply to Former Wards Puller, 03-06-2006 22:02:24
The cranks were the same in the autos as they were in the industrial engines, they just put heavy flywheels onthem for the power units and tractors. The 265 we have would run 5000 if it had the right flywheel balanced or built for the rpm. But if it still has the heavy cast flywheel, 3000-3500 max with a scatter blanket. Thats pushing it if the engine has not been freshened up. They are great engines, and make a 101 massey run pretty good! Chad
Chances R
03-06-2006 16:49:43
third party image
Just wondering if any one out there is running a edmundson aluminum head on there 251/ 265. I have one and i have a edmundson aluminum dual carb intake manifold.
Fordpuller
03-06-2006 16:26:03
After a full balance job (clutch, flywheel, crank, rods, pistons, front pulley), I buzzed mine to 6000 with no trouble. Make sure you use heavy valve springs as you don"t want them floating and smacking the head. If you need a cam to get you there, I still have the one out of my old puller.
Scott Mc
03-06-2006 19:11:07
 Re: Massey 101 RPM in reply to Fordpuller, 03-06-2006 16:26:03
Just wondering what valve springs you would reccomend using? I"ve had my cam re-ground, cylinders bored, had .060 ground off head, added electronic ignition, homemade INT. and EXT. with dual up-draft carbs., port and pollished, and completely balanced engine
Do you think this will get me 6000 rpm???
Fordpuller
03-07-2006 08:40:08
 Re: Massey 101 RPM in reply to Scott Mc, 03-06-2006 19:11:07
Maybe. I think your cam specs will be a key factor to hitting your target. It sounds like you are on your way though with a good intake/exhaust. I hogged my intake ports out to get better flow and used a cam grind that was way bigger than I would have expected. The cam grinder said a flathead needs a lot of duration. I think my numbers were 310/320 @0.50 and .432 lift on 108 center line. At these numbers, it had to wind to 4000 just move out of its own way.
I used a heavy dual outer spring from a set of roller cam springs. Only use the outer spring as you don"t want 230# of pressure on the seat. And, make sure the coil bind limit of the spring has an extra .060 at the top of the lift.
Strange Brew
03-06-2006 16:22:48
If its rebuilt and balanced, 4500 is not a problem, except you will need some heavier valve springs, and a electronic ignition will help, ours will float stock springs at just under 4500, and ours is bone stock, and half worn out.
