Farmall H
Kevin
03-06-2006 13:46:46
I am looking to pep up my H just a touch. I pull it in the 4500lb class and right now it is totaly stock with new 12.4 tires on 11" rims and it weighs 4300 lbs. Its alittle underweight but at some pull i can sneek it into the 4000lbs class. Im not sure how its insides look but i am pretty sure it could use a good valve job. I cant spend much more than $500 becuase i am only 16 and it aint easy for me to keep everything going i have going on minimum wage, my mh 44 is consuming all the money. I lack materials and a welder to make wheelie bars so i was just going to buy a set. Does $230 sound to steep for a set of pre made adjustable wheelie bars with all the hard ware included? That money will not count against the $500. If the piston look good i am going to leave the bottom half alone and probly just get a good valve job, cam ground, and a new gov spring for more rpm. If i pull the head off the cam and all will be attactched to it, right? If i just take it to my machine shop/mechanic and tell them the bore and stroke and what rpm im running will they beable to do a good job or will they need more? Thanks for any help, i apreciate it as i dont feel like getting sucked into a $4000 build like with the massey 44 when i go to the shop.
MJF
03-10-2006 22:00:05
 Re: Farmall H in reply to Kevin, 03-06-2006 13:46:46
I woudn't worry about the wheelie bars for all your doing to it. That'll give ya a little more money to put into the motor. Whys it so heavy, mine get in the 4000 no probs. Take off the belt pully and take out the pump then you can shed quite a few pounds A nice set of Firecrater pistons would help out but since you don't have much money head work is a good idea
ChadS
03-06-2006 16:53:54
$230 aint bad if they are built well. Look under the valve cover and see what the head casting number is. If it a 8043 casting, then you can do some work to it, if its not a 8043 it may be an old distillant head and aint worth putting alot of money into it. if it is a 8043 head, and you know someone who can get you a deal on the parts, you could put all new parts in it, and shave the head for right at 500. 8043's are a good cyl head, you can mill them .125 if never been milled before, just have to be conservative on how much you mill off. a simple valve job can run anywhere from 150-225 these days, and that may be just what it needs to make it good. There is not much you can do for 500 if the head is anything other than a 8043. 8043,,, your good to go! You can swap the cam later, with the head still on, the cam is in the block, not in the head. Located behind the cast iron timing cover. Find you a 350 cam, then later put on a 350 manifold and M carb. (If rules allow) That makes a nice ol H come to life. You could do all that for less than 1000. way less. (head work included if the shop dont hose you) $4000 on the ol 44 Massey huh? What did ya end up doing to it? Have you ran it yet? ChadS
