M with 450 block
Devin M
03-05-2006 16:24:15
If I was going to put a 450 block in my M how hard is it to adapt the block to the trany. What is the bigest block i can go with and still get away with it
ChadS
03-07-2006 12:45:01
 Re: M with 450 block in reply to Devin M, 03-05-2006 16:24:15
May as well get you a SM-450 flywheel and clutch while your swapping engines out. Bigger clutch, and heavier flywheel. Would make the engine complete!! ChadS
randy hall
03-06-2006 18:16:01
the biggest block that will bolt up to your 'm' bell housing would be an 806 engine.
AC
03-05-2006 17:59:00
bolt it to the motor plate. bolt it in. Tell me, what bore are you looking at?
Jeff STN
03-05-2006 17:30:50
It will fit right in,with no trouble.It is the biggest you can put in there.Just bolt it in.
Bencie
03-06-2006 13:59:50
 Re: M with 450 block in reply to Jeff STN, 03-05-2006 17:30:50
The neighbor has an "M" with a W-9 engine in it. More work but it fits. 335 cubes.
ChadS
03-07-2006 12:43:21
 Re: M with 450 block in reply to Bencie, 03-06-2006 13:59:50
Id like to see that one! Chad
