M block
Devin M
03-05-2006 15:31:45
I have a Farmall M with a junk block. I would like to build a pulling tractor. I was wondering if i should get another m block and rebuild it or should i get a block out of another tractor like a a 400 or 450 and put it in my M. I would like to pull in the farm stock class
half breed m
03-05-2006 19:56:24
 Re: M block in reply to Devin M, 03-05-2006 15:31:45
how do you make a new casting number hmmmm.
must be somthing new.
RichH
03-05-2006 20:57:39
 Re: M block in reply to half breed m, 03-05-2006 19:56:24
The right casting numbers, molding clay, JB Weld, auto spray undercoating and a good job of grinding off of the wrong numbers.
AC
03-06-2006 04:13:14
 Re: M block in reply to RichH, 03-05-2006 20:57:39
Why would you go through that much trouble? If you are in farmstock, run what you can run in an M block. Maybe this guy only want 4.125 and he is gonna spend a BOATLOAD of time and money doing stuff he don't have to do?? I don't know...just a thought...
FatRedneck
03-05-2006 15:44:32
definitely go with a 450 block, not just for displacement, but for durability and strength. if its against the rules who cares, you can get replacement serial # plates and install em wherever you want on the block since 450 serial # plates arent in the same place as the M.
AC
03-05-2006 16:09:02
 Re: M block in reply to FatRedneck, 03-05-2006 15:44:32
yeah, but its kinda hard to hide a casting number
ChadS
03-06-2006 13:02:21
 Re: M block in reply to AC, 03-05-2006 16:09:02
Ever hear of dont ask dont tell? There are some blocks that do not have the CI stamped or casted into the side of the block,,, so its a toss up. Most places let the M's run the late blocks, unless your pulling in stricter classes. AC, sorry i missed you down there the other day,,, I havent forgot. So, be patient. in about 3 weeks Ill be able to take care of business. Ill be in touch. ChadS
AC
03-06-2006 14:48:24
 Re: M block in reply to ChadS, 03-06-2006 13:02:21
Yeah, now that I think of it, there are some blocks that are not stamped, I think I remember hearing that..I totally agree with "dont ask don't tell" If someone puts the brains into figuring something unique out, more power to them! Chad, thats fine...drop me a line when its time...Andy
