Gear reduction starter
LW
03-22-2002 15:04:48
I am looking for a gear reduction starter that will repalce a 35mt delco with 13teeth and a 1.815 dia. cw ?
G Taylor
03-25-2002 21:35:42
 Re: gear reduction starter in reply to LW, 03-22-2002 15:04:48
Summit Racing in Ohio will mail order high torque gear reduction staters to your door for reasonable $$$.
nst
03-26-2002 04:52:12
 Re: Re: gear reduction starter in reply to G Taylor , 03-25-2002 21:35:42
Ya if you've got a small block chevy in your antique that would be great.
G Taylor
03-27-2002 19:58:30
 Re: Re: Re: gear reduction starter in reply to nst, 03-26-2002 04:52:12
Lots of those Delco starters & mounts will mix & match with a little tinkering.
MM
03-23-2002 18:03:51
12 tooth 1.820 cw is common are u sure it is 13 T what is the delco # of the original 35mt will try to help if I can. This has got to be on a case.
lw
03-24-2002 07:28:05
 Re: Re: gear reduction starter in reply to MM, 03-23-2002 18:03:51
No it is a moline, it is 13teeth i have 3 of the original starters off a gbd i will get the number off the old starter.thanks LW
