Stroker A
MN JD
03-04-2006 07:58:10
Just wondering if the cam has to be clearanced in an A, wanting to put an 8" stroke with rods out of a 4020. The tractor has a camshaft reground from Robert"s Carb. Has pretty decent power but will not hack 2nd gear in 5500lbs class.
Torquenut
03-05-2006 05:14:46
 Re: Stroker A in reply to MN JD, 03-04-2006 07:58:10
I had a 8.25 stroke in a mid series A with Farmall M bottoms. I had to notch the cam for clearance and grind the back wall just about through for clearance there.
My honest opinion if you are looking to have your crank stroked and do not just have that 8" crank and rods laying around I would highly recommend going to 9" or 9.25" it will cost the same just slightly more work. You will not be looking back!!!
MN JD
03-05-2006 18:27:59
 Re: Stroker A in reply to Torquenut, 03-05-2006 05:14:46
Only going 8" because the weight classes we pull. Have a friend that has a 9" stoked A and has too much power for those weights. We can only run 2 sizes over stock on tires, and 3 to 5 mph, so having 65 horses work better than 90 horses.
jd b puller
03-05-2006 19:18:26
 Re: Stroker A in reply to MN JD, 03-05-2006 18:27:59
I've never heard of "too much power" before. I think Torquenut is right, if you only go 8" you'll be sorry. There will be B's out there with more cubes (and RPM) than you. It's going to cost you about the same to go 9" as 8". In theory, 8" would never break, but...
MN JD
03-05-2006 19:38:12
 Re: Stroker A in reply to jd b puller, 03-05-2006 19:18:26
Can only go 10% over on RPM, so yes a B will be running faster than we will, and yes there will always be someone bigger. Can have too much power when tire limitation apply. Only have so much square inches on the ground, and cannot run cut tires. Like I said before, have to stay below 3 mph in some pulls and 5 mph in others.
jd b puller
03-04-2006 18:21:11
Out of curiosity, did you have a crank for an A already stroked to 8", or were you looking at getting yers stroked to 8?
Mike n Mo
03-04-2006 14:42:04
I think it should go together without any grinding. It might need some minor clearancing, you can take some off the rod if you would rather grind that than the cam. mike
