Farmall H Sleveless
Farmall H Pulle
03-03-2006 08:44:36
Has anyone ever had troble running an h sleveless. Some people say if you run them to much you can melt them down is this true?
Miles
pullin
03-06-2006 07:39:28
 Re: Farmall H Sleveless in reply to Farmall H Puller, 03-03-2006 08:44:36
I,m running a H block with 3.750" bore,no hard block,custom pistons,13.5 compression & over 295 cranking psi. been running this block for 5th year now.
tape measure
03-03-2006 19:52:57
I wouldn't worry about it. if you are pulling, you'll never wear them out. you'll never get enough compression with that small bore to do any harm, except for pre ignition.
ruler
03-03-2006 19:05:38
Melt down what? Not enough info.for compresson.When you find out what?Come on boys.
ruler
03-03-2006 09:31:35
5 years sleveless.
FatRedneck
03-03-2006 17:41:11
 Re: Farmall H Sleveless in reply to ruler, 03-03-2006 09:31:35
when you find out tell me, i'm building one without sleeves soon, do ya know what kind of compression 3-9/16 pistons will make without sleeves?
jhb
03-04-2006 05:09:25
 Re: Farmall H Sleveless in reply to FatRedneck, 03-03-2006 17:41:11
165 pounds with proper interal parts.
