more power
rick hull
03-01-2006 12:45:51
I'M LOOKING FOR SOME MORE POWER FROM MY 5 STAR.I RUN IN CLASSES THAT ARE 10% OVER STOCK RPM MOST OF THE TIME,BUT ALSO RUN SOME 3000 RPM MAX CLASSES.I'M RUNNING 4 5/8 PISTONS 354C.I.D. 104A406 HEADS,ON LP GAS.I CAN'T AFFORD TO STROKE IT,BUT WOULD LIKE TO GET 100 HORSE OUT OF IT.ANY IDEAS ON HEAD/VALVE WORK AND CAMSHAFT SPECS.
b barenie
03-01-2006 19:48:49
 Re: more power in reply to rick hull , 03-01-2006 12:45:51
hold on
you can buy a (G) crank, off-set grind with (u) rods, and I don't know off the top of my head what piston's they use. You've got the rite blocks, For about a $1200.oo U.S. CURRENCY, THAT WOULD BE A HUGE IMPROVEMENT ! THAT TAKE YOU TO 403CI
Mopower
03-02-2006 06:47:40
 Re: more power in reply to b barenie, 03-01-2006 19:48:49
With an offset ground G crank and 4.81 bore you could get 445 cubes or so. Good for say 125 h.p. The other option is buying a 403 power unit and installing.
rick hull
03-03-2006 00:46:48
 Re: more power in reply to Mopower, 03-02-2006 06:47:40
sorry about the piston size,should have bean 4 3/4". we have a few g crack pullers around here, some say their pushing 140 hp.all said and done it"ll cost about $2800 to stock a g crank and bore,plus parts,i"m told. i"m going to insall bigger valves and open up the heads some. i can"t deside if i sould recam or not.i"m told a cam will have about a 700 rpm sweat spot.if i get a cam that pulls at1700-2400 rpm will i be hurting my low end hp.will that cam be big enough for the 3000rpm classes.i have turned 2800rpm but with the stock cam i don"t know how much good it does.
Mopower
03-03-2006 04:12:49
 Re: more power in reply to rick hull, 03-03-2006 00:46:48
Talk to Scotty at Berry Cam (no relation). He is doing one for our UB right now. He needs to know just a few things and seems to have a BIG handle on stuff. Said that tractors are now 75% of their business.
Telephone 320-395-2377 FAX 320-395-2241 Address 1948 175th St. P.O. Box 697 Lester Prairie, MN 55354 Electronic mail Attn: Scott General Information: [email protected]
AC
03-02-2006 17:09:36
I think you are missing the boat here...he said he can run (on occasion) 3 Grand..it'd be ALOT more HP than 125 @ 3K...
b barenie
03-01-2006 19:43:34
that come's out to 336ci
turn more rpm's
otherwise your there !!!!! !1
