Horsepower
G Pulling Tract
02-27-2006 21:24:22
Have a 47 John Deere G, what is the best way to get 70-75 horsepower out of my tractor. Everything on the tractor is stock right now. 100% good old original tractor. Any experienced input from you guys would be appreciated!!
GPULLER
02-28-2006 10:07:52
 Re: Horsepower in reply to G Pulling Tractor, 02-27-2006 21:24:22
To get 70-75hp your going to have to bore .090 or .125 with M&W style pistons, get a unstyled G head along with head studs, pushrods, elbow that connects the carb to the oil bath. When running this combo your going to have run 100 plus octane race gas and you could have head gasket trouble.
If you could settle for 60 hp you'll still need the M&W pistons and can keep your existing head. Mill it down to the eyebrows, do a little port work, a good valve job and port match the manifold, gas manifold would be best but it can be done with the all-fuel manifold. You will be able to run regular pump gas, and not worry about head gaskets.
Dane in PA
02-28-2006 09:14:27
you would want to get larger pistons, bigger block, and maybe a heisler head. I guy my dad was friends with had an unstyled G pumping out 175 hp and an unstyled A cranking out 130 hp. he had the stuff I said above along with it being stroked so much that the "wall" between the crank and the transmision had to be removed so the crank could make its full rotation.
Lenny Kirby
02-28-2006 11:23:54
 Re: Horsepower in reply to Dane in PA, 02-28-2006 09:14:27
Holy crap how many RPM's was he turning for those hp figures?
Dane in PA
02-28-2006 15:31:30
 Re: Horsepower in reply to Lenny Kirby, 02-28-2006 11:23:54
2100 RPMs at that hp.
