Need 7 inch D pistons
lastein
03-21-2002 19:15:38
Anyone have a source for 7 inch aluminum
pistons new or used? Or possible someone that could sleeve a D block to 7.5 inches. I understand Jahns foundery down for at least a couple more weeks with 10 week backlog of orders.
JD675X7
03-22-2002 15:54:26
 Re: Need 7 inch D pistons in reply to lastein, 03-21-2002 19:15:38
lastein; I have been kinda playing with the same notion. Do you think you can take the D cylinders out to 7.5"? If you find a sorce of pistons & figure out a way to get that kind of bore please E-Mail me as I would like to try something like that. Are you looking at more stroke also?
lastein
03-22-2002 16:46:56
 Re: Re: Need 7 inch D pistons in reply to JD675X7, 03-22-2002 15:54:26
JD675X7,
Plan to finish tearing down the D this weekend and do some measuring. Will stroke all I can without having to redrill crank to oil. Do not know if 7.5 bore sleeves will go into the block at this time.
03-22-2002 15:45:35
FUNDERBURKE MAKES PISTONS AND DOES BLOCKS.
RONNIE OR RICK FUNDERBURKE.
ROCKHILL,SC.
lastein
03-23-2002 13:10:43
 Re: Re: Need 7 inch D pistons in reply to ??, 03-22-2002 15:45:35
Thanks for the information!
