G Differential
MN JD
02-22-2006 20:19:36
Hi.
I am a antique tractor puller in northern Minnesota, I have a John Deere G that I am building to pull in 6500lb class and heavier weight classes. Do I have to look at beefing up the differential in my tractor or will it be ok?
The tractor is bored and stroked to an amount that I shouldn't have to worry about powering out in lower gears. It has a factory head that has been flowed and a Johnson lp manifold to match the head. It has a camshaft to match the amount cubic inches that the motor is. I am going to be running 18.4x38 tires on 16 inch rims.
In the process of rebuilding the tractor to pull, I replaced the transmission bearings, the axle bearings and races, differential bearings and races, and first reduction bearings.
DP
02-23-2006 20:16:21
 Re: G Differential in reply to MN JD, 02-22-2006 20:19:36
I had the three pins sheer off in my 46 GM a few years ago. I talked to a retired John Deere mechainc about that. He said that he had seen a few 4020's that had that happen. He adivised I replace the complete differential assembly, since it had slipped so far, and had me drill another hole half way between the existing pins just a shade smaller then the pins to be installed, and then drive the new pins in. The pins need to be a soft grade bolt and because the cast drills better, the holes will be more in the cast when your done. Thats been some years back, and no problem.
DSK
02-23-2006 07:10:27
It sounds like you've done your homework pretty good in the back room of your G. If you plan on pulling it heavier than 8000#, I would reccomend welding the differental drive gear to the spider, just 3 1 inch welds on each side will do. The drive gear is fastened to the spider with 3 rivets from the factory and I have seen them shear on stroker tractors being pulled heavy. The differental is definately the weakest link in the G powertrain.
