Tire size?
REDJD
02-20-2006 07:46:56
What was the largest tire that the JD model A came out with from the factory? Thanks
Dane in PA
02-20-2006 17:15:12
 Re: Tire size? in reply to REDJD, 02-20-2006 07:46:56
What DSK said is correct, but, my dad has a '51 A with 14.9x38s on it and those big tires make it look awesome! look into it.
Dane
DSK
02-20-2006 11:56:50
The Model A parts book lists part # AA3043R as a rim available for a 12-38 tire which would be the modern equivalant to the 13.6-38. It was available for the cast wheel only, not as a 9 bolt pressed steel wheel. Most A's [General Purpose] were equipped with 11-38 tires which would be the modern day 12.4-38. These numbers apply to commonly equipped General Purpose tractors above serial#488000,which is the latest serial break listed.
ejr-IA.
02-20-2006 09:57:41
Does 11x38 sound right.
